Assembly of Pixie feeder
Reginald Alders 1 | 20/09/2013 16:28:58 |
4 forum posts | Has anyone built the Pixie feeder from Mew 203 and how easy is it to put together . |
Paul Barrett | 20/09/2013 21:44:12 |
59 forum posts 16 photos | I built it after buying the printed circuit board. It is easy enough to build although the article does not quite explain it all. I found it very limited on the speed it would drive a stepper. I certainly could not get it to operate it as described in the article despite messing about with the program. I was also interested in the rotary table program thinking it would make a programmable indexer but in the end I bought a rotary table module from steve ward and built my own which does everything i want. |
Reginald Alders 1 | 21/09/2013 10:03:21 |
4 forum posts | Many thanks Paul. I also thought about using it on an indexing head to cut gears. I will probably not bother now . Does Steve Ward have a website |
John Stevenson | 21/09/2013 10:51:08 |
![]() 5068 forum posts 3 photos | http://www.worldofward.com/rotarycontroller/overview/
Steve Wards web site.
This thread is also a good read.
http://bbs.homeshopmachinist.net/threads/59781 Edited By John Stevenson on 21/09/2013 10:52:22 Edited By John Stevenson on 21/09/2013 18:31:22 |
Paul Barrett | 21/09/2013 13:25:23 |
59 forum posts 16 photos | Reg. I have just used the steve ward indexer module to engrave a new dial for my lathe. I wanted 100 divs which would be 3.6 deg or 3 deg 48 mins. With the indexer you can either set divs or degrees and it is so simle. I think mine worked out about £80 complete.I bought the module and keyboard from steve. got the case from rapid electronics and the stepper module from ebay. I fitted it all in the case and made my own overlay. I also stuck a 40mm fan inside as well as the heatsinks get a little warm. Power supply came from an old laptop charger. I have some pics if you are interested. Paul |
Reginald Alders 1 | 21/09/2013 17:53:46 |
4 forum posts | Paul. sounds like an bargain. do you have the link to Steve Wards website, I tried John Stevensons link but it didn't work. Could I have a look at the Pics Reg |
John Stevenson | 21/09/2013 18:32:41 |
![]() 5068 forum posts 3 photos | Link now fixed - sorry |
Paul Barrett | 22/09/2013 08:15:02 |
59 forum posts 16 photos | Reg. I have sent you a pm. Paul |
Reginald Alders 1 | 22/09/2013 15:39:41 |
4 forum posts | Many thanks Paul i've looked at your pics and some demos on youtube so I have been on Steve Wards website and ordered the indexer module , All i have to do is find the time to assemble it when it arrives. Also many thanks John for your help . I will keep you posted when I get around to assembling it Reg |
