paul hardwick | 15/08/2013 13:18:46 |
10 forum posts | I recently bought one of these machines and the dowel for locating the head to 90 degrees is missing can anyone help with sizes, i think it is a 2 degree taper dowel, but may be wrong. Many thanks Paul. PS I have been in touch with Boxford and that was a complete waste of time. Edited By paul hardwick on 15/08/2013 13:19:23 |
KWIL | 15/08/2013 17:01:57 |
3681 forum posts 70 photos | Just measured the taper pin. 42.7mm long, 11.8mm at widest point and 9.8mm at the narrow end, which I make 2.68 degrees included angle/ It has a M6 threaded hole and a counter sunk collar for the outside wider end. You tap it into place and then just nip the caphead M6. To remove you merely tighten the caphead and it withdraws. |
paul hardwick | 15/08/2013 19:30:35 |
10 forum posts | Thanks for your help. |
