david newman 9 | 02/08/2013 18:06:52 |
47 forum posts | Hello, I have been offered a set of castings (completely unstarted) for the Brunell Tandem Compound engine, has any member on here built this model.and was it worth the effort , any major problems and will it run on air OK.? Hope someone can help me. Regards David
Jo | 02/08/2013 18:14:38 |
198 forum posts | Yes. I documented the build here: **LINK** You will need a compressor with a high CFM to run it. Jo |
david newman 9 | 02/08/2013 18:43:25 |
47 forum posts | Hello Jo , that's not the Tandem Compound I have been offered, the one I am inquiring about the cylinders are inline ? David |
JasonB | 02/08/2013 20:13:36 |
![]() 25215 forum posts 3105 photos 1 articles | Jo's is the double version of yours with two pairs of tandem cylinders side by side ( 4 cylinders total). The two models share a lot of the same parts so Jo's build and comments apply to your engine Yours is at the top of this page hers just below. Here is one half of Jo's which is basically what your engine will look like
J Edited By JasonB on 02/08/2013 20:19:00 |
graham howard 3 | 21/08/2013 09:26:22 |
4 forum posts | Hello David just thought I would let you know if you decide to take on the project and there are any issues with our castings just get in touch and I will replace any castings that do not come up to scratch are you ok for drawings ? Regards Graham Brunel Steam Model Engineering |
