wherecan you get this in suitable sizes
daniel johnston | 23/07/2013 23:22:24 |
2 forum posts | Hello Im having sime problems locating CHROME-VANADIUM STEEL as stated on my plans for ecentrics and couplings may I ask if there is an equivalent or what other people use Many thanks |
David Littlewood | 24/07/2013 00:05:39 |
533 forum posts | I have used EN24T with success for highly-stressed parts. Not sure what its composition is, but it has a UTS many times that of mild steel, but still turns fairly easily. It is readily available from various of our usual retail sources; if they don't have it in stock they will certainly get it for you. I can't remember offhand where I got mine from, but it would have been Mallard Metals or Noggin End Metals. David |
David Jupp | 24/07/2013 08:32:27 |
978 forum posts 26 photos | Chrome Vanadium doesn't really tell us (or you) what the steel is - just 2 of the alloying elements it contains. I have seen those words on a lot of spanners over the years - though I have no idea why spanner manufacturers should go to the expense of adding the letters to the forging dies. Assuming there are no particular chemical issues relating to the environment of use, select on strength of the steel for the required duty (on BS steels the 'condition' letter tells you the strength). Don't worry too much about composition of the steel. Where there will be sliding or rubbing against another steel component, ensure a strength (hardness) difference between parts to reduce scuffing/galling. For safety critical items (pressure vessels, lifting equipment - possibly couplings) the toughness of the steel is also important in avoiding fatigue failures. Toughness generally reduces as strength increases, so stronger is not always better - a balance is required. BTW EN24 is a Nickel Chrome Molybdenum steel having about 0.4% Carbon (also contains Silicon and Manganese) .
daniel johnston | 24/07/2013 19:57:02 |
2 forum posts | Firstly many thanks for such prompt replies this is much appreciated it would seem agreed that metal details are poor as I have actually triple checked and just chrome vanadium steel so as for the details it is for a 5" hunslet 0-6-0 tank engine the parts it states are the; combination leaver, union link, radius rod, return crank,eccentric rod. But with the differences in grades id rather be sure than waste money or end up with catastrophic failure thanks again Daniel |
duncan webster | 24/07/2013 22:20:39 |
5307 forum posts 83 photos | For those components I'd be amazed if bog standard mild steel wasn't strong enough. It worked on my 5"g locos, and hundreds of others. If you want something a bit stronger then EN8, but I can't see that it's necessary |
Stub Mandrel | 25/07/2013 20:43:12 |
![]() 4318 forum posts 291 photos 1 articles | My guess is all those parts could be from one piece of gauge plate. Easy to harden & temper. Neil |
