Problems with sealing valve chest to Cylinder
Chris Hillier | 23/05/2013 17:09:24 |
4 forum posts |
I have just about finished putting all together and have used a foot pump as Mr Hughes suggests, to try to check for leaks. I seem to have a direct leak to the exhaust !! I suspect problems where the valve chest fixes to the cylinder. Indeed the traditional Fairy Liquid solution test for leaks has bubbles coming from the bottom corner join between valve chest and cylinder. |
JasonB | 23/05/2013 17:32:13 |
![]() 25215 forum posts 3105 photos 1 articles | If your machined surfaces are fairly good then I would just go with a liquid gasket as there is no need to make allowance for the thickness of any gasket paper.
J |
Chris Hillier | 12/06/2013 18:04:06 |
4 forum posts | Thanks very much Jason. I have been in touch with Loctite's tech advice dept and received some suggestions They suggest Loctite 5910 after a thorough degreasing I'll see how I get on Regards Chris |
