Brian Wood | 02/04/2013 10:44:54 |
2742 forum posts 39 photos | Hello everyone, I have a backplate for threaded nose fitting removed from a 5 inch Pratt 4 jaw chuck and no idea what it used to fit. The thread is 1 5/16 inch by 11 TPI Whitworth form. It seems an odd size that I can't match so can anyone identify it please? The nose register diameter is also 1 5/16 inch. Brian |
JasonB | 02/04/2013 13:47:35 |
![]() 25215 forum posts 3105 photos 1 articles | Are you sure its not 1" BSP which is 1.309" very close to 1 5/16" and 11tpi Can't help with the lathe it went on but could it be someone was intending to use a pipe flange as a backplate and never got round to rethreading? |
Brian Wood | 02/04/2013 14:00:05 |
2742 forum posts 39 photos | Hello Jason, Thank you for that information, the sizes are too close to sort, so you may well be right..It has been machined tike a lathe backplate too and I never thought it was anything else when I fitted a Myford plate to the chuck in it's place. I can always bush it and remachine it for my use, but it might just suit someone as it is Regards Brian |
