Alexander/ Deckel 16mm Collets
frank brown28/01/2013 13:05:50
436 forum posts
5 photos
I have a high speed milling head made by Alexander, but is a Deckel clone which takes 16mm collets, I have some duplications and some omissions. Having spent a couple of hours on Google,and I have found no references to them, except from lathes.co.uk, who mentions them as "type unknown". My ones are marked "GALEX a" and " GFA D" . BTW, I have a list of the 20mm SO/SOE cross references (U2 , 355e , Kuhlmann SO2, Alexander 2CF and Hassberg), though I think some (most?) are for the cutter grinder, or the pantograph. Grr!, isn't life complicated!!! Ideally I would like to swop my 4mm for a 1/4", and a 3/16" for a 1/2". Any suggestions or likely sources?
Frank
Robonthemoor21/02/2014 00:45:32
211 forum posts
45 photos
Just had a look on ebay & found Deckel FP1 George Alexander cutter Grinder Collets item No 29108421473 could these be the ones! My mill is a Deckel FP1
Rob
Phil P21/02/2014 13:13:54
851 forum posts
206 photos
Be careful about buying the 16mm collets that are advertised, they do not have the correct thread diameter to fit a Deckel high speed head.
The correct ones have a Lownherz thread approx 14.5 diameter but the new ones you can buy have a full 16mm diameter thread. I have been hunting Deckel 16mm collets for years and they do not turn up very often.
Here is my imperial set which I was very lucky to find new. I would love to find some similar metric ones but so far I have only managed to find a very well used second hand set.
And also a drawing of the more common Deckel 20mm collets.
Robonthemoor21/02/2014 16:13:22
211 forum posts
45 photos
Thanks" this looks the one, my mill is a deckel FP1 & the thread looks the same too. May have to buy one ( I need1/2" to try.
Rob
