Key?????
Simon B | 24/11/2012 09:53:27 |
![]() 12 forum posts 3 photos | The ML7 I have came with 4 or 5 change wheels of varing size - ok so far. However, they are all plain bore, none have a keyway. Does this sound correct? Simon |
John Stevenson | 24/11/2012 10:03:15 |
![]() 5068 forum posts 3 photos | Do they have a small dowel hole in them ?
If so then they are off the earlier ML2 and ML4 series. |
Simon B | 24/11/2012 10:19:32 |
![]() 12 forum posts 3 photos | The knowledge here is really scary - instant and spot on! John, yes they do! Unless you are going to tell me they are a real rarity and worth a fortune, do you know off hand if they share a common bore in which case I could get a keyway machined? Thanks, Simon |
John Stevenson | 24/11/2012 10:36:17 |
![]() 5068 forum posts 3 photos | Identical gears to the ML7, in fact there were some produced that had the dowel hole and keyway, probably using up old stock.
You just need a 1/8" keyway broaging into them. |
