Trevorh | 30/10/2012 09:40:29 |
![]() 316 forum posts 89 photos | I am just starting the HH Grinding rest and have what may seem to be a simple question, the dovetail cutter, when we say 30 degree or 60 degree from what plane is the angle talking about? What I mean to say is - is it 30 degree from the horizontal or the vertical plane?
Hope I have explained myself thanks |
KWIL | 30/10/2012 09:57:38 |
3681 forum posts 70 photos | Measured up from the horizontal plane. Think about it, if the other way around, the resulting sliding assembly would be very shallow. |
Trevorh | 30/10/2012 10:09:18 |
![]() 316 forum posts 89 photos | To be honest thats what prompted the question when I was looking at it - it just looked wrong so I then started to think which way was the dovetail measured
thanks
KWIL | 30/10/2012 10:12:51 |
3681 forum posts 70 photos | Beware, not all "60 degree" dovetail slides are in fact 60, some are 55! |
Trevorh | 30/10/2012 10:22:29 |
![]() 316 forum posts 89 photos | In this particular case would that really be an issue as the same cutter would be used to create the 2 mating parts, I understand the argument for getting what you ask for ie 60 degree should be 60 degree but as long as I use the same cutter it shouldn't really make a difference - or would it? |
KWIL | 30/10/2012 10:42:54 |
3681 forum posts 70 photos | No, get a 60. What I was pointing out that some machines that look like they have 60 degree dovetails in fact have 55, don't ask! Sussex tools a good source. |
Trevorh | 30/10/2012 10:52:15 |
![]() 316 forum posts 89 photos | Thanks for the tip Kwil I will give them a ring thanks for the advice |
Andrew Johnston | 30/10/2012 11:36:49 |
![]() 7061 forum posts 719 photos |
Posted by KWIL on 30/10/2012 10:42:54:
What I was pointing out that some machines that look like they have 60 degree dovetails in fact have 55, don't ask! I won't ask, I'll just say Bridgeport. Andrew |
KWIL | 30/10/2012 12:10:35 |
3681 forum posts 70 photos | And M300 |
