merlin | 01/08/2012 14:59:45 |
141 forum posts 1 photos | I am having difficulty in finding a fine grit wheel for my 3000rpm bench grinder. I want to get a fine finish on HSS lathe tools so I guess I need an 80 grit, 125 x 16 (or a bit more) wide and to fit a 13mm shaft. Does anyone know of a supplier? Thanks |
David Clark 1 | 01/08/2012 15:27:39 |
![]() 3357 forum posts 112 photos 10 articles | Hi There You don't necessarily need a 13mm bore. You could fit standard plastic washers to reduce the bore. A 60 or 80 grit should do. Something similar to an A60K5V would do. Your local engineers' suppliers should be able to get you one and the washers. regards David
Les Jones 1 | 01/08/2012 17:29:07 |
2292 forum posts 159 photos |
Hi Merlin, Les. Edited By Les Jones 1 on 01/08/2012 17:30:04 |
