Tractor man | 20/07/2012 18:04:20 |
426 forum posts 1 photos | Hi all, I have just been gifted a new workshop 6.3 x 3.3 m inside dimensions and want advice on which machines to put in there, It is as clean as a whistle and I don't want to mess it upi with grinders etc. so was going to put just mills and lathes in there. Anyone any views on what would be a good mix of machine tools. The main shop will house the mucky stuff and fabrication but the new shop is for machining only. Regards T |
NJH | 20/07/2012 20:18:08 |
![]() 2314 forum posts 139 photos | First question - what do you intend to make/do in there? How big will your projects be? Will it be for small models or to repair/ renovate larger stuff? What is the workshop made from? Will it be heated and what sort of insulation does it have? Is the power supply 3-phase or single phase ? If your intention is to build models a la Cherry Hill the answer will probably be a bit different from the one you would get if you intend to build a 71/4" loco or repair full sized traction engines! Regards N |
