3D Printer
Peter Bell09/07/2012 13:03:48
399 forum posts
167 photos
Just reading the article about the 3d printer in the latest MEW and it sruck me that most CNC mills have most of the parts needed to move things around etc. How long will it be before the heated print heads become available as an add on---or am I missing something?
Peter
Another JohnS09/07/2012 14:06:05
842 forum posts
56 photos
Discussed at length on the Linux-CNC mailing list.
People are already doing this, but the trivial "main" issues are:
- interfacing the print head temp. setting and feedback;
- speed of printing; the dedicated RepRap printers have quite high axis speeds.
- if you have the "A" axis electronics, it can drive the extruder.
It really is not that difficult to take, say, the Wade extruder and plunk it on a CNC machine - hopefully I'll have the parts printed by someone else later this week. (then the fun begins!)
Another JohnS.
John McNamara09/07/2012 14:16:32
1377 forum posts
133 photos
Hi Peter
I have wondered the same The print heads are not a big deal, Usually just a close temperature controlled, but small, metal block nozzle heated to just the right melting point for the plastic being used. The feed is based on pushing the plastic into a drilled hole in the block. the force being provided by a small step motor that drives the plastic filament through pinch rollers. The feed has to be in sync with the machine X.Y. feed vector. There is an added complication....At the end of each run the plastic feed is reversed a small amount pulling the filament back into the nozzle and cutting of the feed. There is no valve as such.
In a way similar to a hot glue gun, but they don't normally have a stop mechanism.
I have been toying with the idea of building one. A starting Google search on "RepRap" will lead you to hundreds of posts. and no doubt lead you to other key words to search on, "additive machining" being one.
It would be nice to use an existing CNC machine. I wonder if someone has made a Mach 3 Macro and published a small circuit for the interface? Most of the posts I have read are dedicated machines using a small Arduino processor. even starting from scratch not that expensive if you can scrounge around and already have a manual mill and lathe.
Cheers
Edited By John McNamara on 09/07/2012 14:19:31
