ML 7 cross slide mod
Malc03/05/2012 23:36:35
113 forum posts
6 photos
Hi All,
I am considering fitting needle roller thrust bearings to the cross slide and compound slide screws of my ML 7 to reduce the play. Arc Euro Trade do a kit for the job. Has any one done this mod? Is it successful? Are there any pitfalls? I would be grateful of any comments.
Thanks in anticipation
Malc.
Clive Hartland04/05/2012 08:19:26
2929 forum posts
41 photos
Hi Malc, Yes, I have done my ML10 using the bearings supplied by ArC.
The main problem is that you have to machine the end plate of the top slide and if its the lathe that you are doing then you have no top slide to work with.
How I got round this was to swop the end cap off my Vertical slide and do that one and then just do the swop onto the lathe when complete.
It does work very well but be careful not to tighten the spindle too much when adjusting.
It does smooth out the movement and I am pleased with the result.
