Thiel 158 problem
Y axis power feed failure
steamdave12/11/2011 17:42:58
526 forum posts
45 photos
Does any reader have a good working knowledge of the Thiel 158 milling machine - or know anyone who does?
I have lost power feed to the Y axis. There must be a shear pin somewhere that has failed, but where?! I know about the main one on the left hand side of the column and that one is intact.
Hopefully someone will be able to help.
The Emerald Isle
Springbok12/11/2011 19:53:09
879 forum posts
34 photos
Hi
Try this site
BUT they do not have a manual for the 158 but it may be a starting point for you
good luck
Bob
steamdave13/11/2011 14:53:13
526 forum posts
45 photos
Hi Bob
Thanks for your suggestion. I do have a manual, but it must be based on a later type of machine than mine because there are several differences in it and crucially no shear pin is shown.
The Emerald Isle
steamdave13/11/2011 15:01:44
526 forum posts
45 photos
Hi Rob
Thanks for your input. I will check on the detent next time I can get to my workshop - I'm away at work now. The Y axis did overrun the normal travel limit, but I don't remember any problem afterwards with the feed selector not being able to engage. I engaged the selector but there just wasn't any feed. That is why I wondered about the hidden shear pin.
The Emerald Isle
steamdave16/11/2011 10:22:00
526 forum posts
45 photos
Hi Rob
Managed to have a look at the milling machine. When I select Y axis power feed, the detent rises and when it is deselected, the detent drops. I have tried to remove the selector lever but looks like I need a puller to get it off - possibly a burr on the shaft, then I can have a look inside the detent mechanism.
The Emerald Isle
steamdave16/11/2011 21:37:41
526 forum posts
45 photos
Hi Rob
Many thanks indeed for that useful bit of information. Looks like a partial strip down is required!
The Emerald Isle
