Ryan Curnow | 21/10/2011 17:35:30 |
15 forum posts | Hi Guys
I am completly new to all this, I am a quilifed mechanical engineer and wish to build a Allchin and was wondering what tools are need if I use casts. Also how is the funnel connected to the boiler is it bolted?
Thanks
JasonB | 21/10/2011 17:54:03 |
![]() 25215 forum posts 3105 photos 1 articles | It is possible to do the Alchin on just a lathe inconjunction with a vertical slide for the milling operations and just a bench mounted drill along with a range of hand tools.
However you will find it a lot easier with a small milling machine, something like an X2 would likely cope but don't hold me to that, an X3 size will definately do it.
The chimney saddle is rivited to the smokebox though you could use unslotted roundhead screws with nuts from the inside. The smokebox in turn is rivited or screwed to the end of the boiler.
Its worth getting a copy of W.J.Hughes's book on building this engine as it shows a lot of the machine setups, based on just using the lathe.
The Alchin is a very detailed design a 1" or 2" Minnie would be a lot simpler, also I would suggest you try a small stationary engine first to see how you get on and to learn how to use the machines and get the correct fit and finish on parts.
J Edited By JasonB on 21/10/2011 17:58:22 |
Ryan Curnow | 21/10/2011 18:04:24 |
15 forum posts | Thanks J
Another stupid question lol
![]() Thanks Ryan |
JasonB | 21/10/2011 18:25:38 |
![]() 25215 forum posts 3105 photos 1 articles | You will have to make a considerable number of parts either from raw castings, bar or sheet metal. Probably 1000-1500 hours work. All the parts from Reeves need work on them from simply drilling a hole or two to completely machining.
If you want a bolt together kit then have a look at Steam Traction World and even then you need to do a bit of fettling as well as painting. Their 2" Burrell would be the nearest to an Alchin
J |
