TrevorK | 06/10/2011 12:24:41 |
45 forum posts 4 photos | Can any Simplex builder tell me what clearance they've used from the wheel rim to the foot of the guard irons. I read on the Simplex site that there were no dimensions given for these in the ME articles, but don't have any drawings now. I think 0.45"? Thanks Trev |
Mike Wainwright | 07/10/2011 07:32:16 |
149 forum posts 8 photos | Trev
I have a set of Simplex drawings and I am quite happy to check the dim for you but I don't know what you mean by Guard Iron. Let me know and I will check the dimension for you
TrevorK | 07/10/2011 09:45:14 |
45 forum posts 4 photos | Mike They're the offset angle plates bolted to the front and back ends of the mainframes, cosmetic but shown in Martin Evans' drawings. My Simplex was built by my father. The poitioning on the frames is fine but they're too long as there's to little clearance when the loco is on rails. Thanks Trev |
Colin Abrey | 07/10/2011 10:39:48 |
17 forum posts 2 photos | Hi Trev,
I think I measured mine from the GA on sheet 1 of the drawings. The front are 1.1/4 below the lower edge of the frames and the rear are 1.3/4 below the lower edge of the frames. Material is 1/8 thick and the joggle is 3/8. The front are hard against the cylinders and have 3 x 6 BA screws vertically, the rear are "T" shaped with 3 x 6 BA screws horizontally.
Hope this helps.
Colin
TrevorK | 09/10/2011 11:23:00 |
45 forum posts 4 photos | Colin Many thanks. The back guards were OK, I've shortened the front ones to 1 1/4" and they're all the same clearance now. On the front the joggle on mine is bigger - the point of the guard is directly over the centre of the rail. Trev |
Speedy Builder5 | 23/10/2021 12:26:17 |
2878 forum posts 248 photos | Reserection of an old post. There is scant information on the SPEEDY plans as to exact location, but more importantly - What do these guards do ? |
