Steambuff | 28/09/2011 22:09:39 | ||||||
![]() 544 forum posts 8 photos | Silly question, I have just received my water cut frames from Blackgates for the Darjeeling 'B' Class. I have marked the frames out and are about to start drilling.
I just want to make sure that I am drilling the correct size.
Those marked say Dia 1/4 etc are obvious ...
But there are some that are marked say 8BA (Does this mean I have to Tap it 8BA?) - The part that fixes to it says 8BA Clearance. (ie. Oil boxes)
So do I assume that everywhere it says 8BA, I drill and tap the hole for a 8BA bolt?
Tel | 28/09/2011 23:28:42 | ||||||
![]() 157 forum posts 28 photos | Yes, that's how I would read it. | ||||||
ady | 29/09/2011 00:30:31 | ||||||
612 forum posts 50 photos | 8ba is pretty small.
Steambuff | 29/09/2011 01:13:22 | ||||||
![]() 544 forum posts 8 photos | Yes 8BA is pretty small, some of the parts use 10BA !!!! | ||||||
Tel | 29/09/2011 02:57:48 | ||||||
![]() 157 forum posts 28 photos | It's all relative - sometimes even 10 BA can be huge! | ||||||
peter ravenscroft | 29/09/2011 17:56:16 | ||||||
100 forum posts 3 photos | hi steambuff
when you make the brakets for the tank check the size on both drawings (frames and tank)
wait untill you have to start tapping 12ba threads they are even smaller(con rods coupling rods etc.)
regards
peter | ||||||
Steambuff | 29/09/2011 18:06:40 | ||||||
![]() 544 forum posts 8 photos | Peter,
Thanks for that, I will check both parts on all components (Frame, Bracket and Tank) and both in ME and on Ray's drawings.
I usually double or tripple check measurements ... and still get it wrong.
