chart for scale bolt sizes
Adrian Kruger | 05/05/2011 11:30:52 |
6 forum posts | yers ago i found on the net a chart of scale bolt sizes , that listed near as possible for Loco's 2 1/2 to 7 1/4 gauge and traction engines 1 inch to 4 inch scale the copy of it i have is starting to fad and was wndering if anyone else had see it of had a copy or had some ideas on it or the subject
adrian |
Paul Boscott | 05/05/2011 13:39:10 |
![]() 99 forum posts 21 photos | I have recently been faced with a similar problem deciding the size of nuts bolts and studs to use on the 1/12 scale extrusion press that I am making. On my CAD system I drew up the BA range 14BA to OBA at 1:1 then scaled them by times 12. Using these on the 1:1 drawing of the press, when I divided this 1:1 drawing by 12 I then had the correct looking BA fixings for the model.
see www.boscott.co.uk for more details
Paul |
John Baguley | 06/05/2011 00:54:20 |
![]() 517 forum posts 57 photos | Hi Adrian, I think this is what you are looking for: http://www.modeleng.org/software/ron_head/Bolt%20sizes.pdf John |
Adrian Kruger | 08/05/2011 12:14:11 |
6 forum posts | thanks for the help fellas , the next question may be a bit of a challlenge , but can anyone tell me where to find some dimensions for Lamp Brakets to fit my 7 1/4 Gauge Addams 415 Class i am building, either type would be OK , i am after the ones which are on the back af the tank in particular as this is the part i am building at the moment
cheers
adrian
Edited By Adrian Kruger on 08/05/2011 12:14:50 Edited By Adrian Kruger on 08/05/2011 12:15:17 |
