Chippychap | 25/04/2011 05:02:41 |
![]() 11 forum posts | Wishing to oil the full extent of the slide beds I have accidentally withdrawn the cross slide to the extent that the threaded rod seems to now be disconnected from its location at the far end.
Now turning the handle does nothing. The threaded rod still turns as I can feel it turning under the slide but it produces no traverse.
Are there any nifty trick to connect it? |
John Olsen | 25/04/2011 06:11:07 |
1294 forum posts 108 photos 1 articles | Usually you can slide the cross slide back by hand until the lead screw meets the nut inside, then by gently turning you can pursuade it to engage. If the gibs are adjusted too tight you may find it difficult to do this, but then they shouldn't be all that tight. regards John |
ady | 25/04/2011 08:42:58 |
612 forum posts 50 photos | They leadscrew should go out and in to the leadnut no problem, if you have a taper turning attachment type thingy the leadscrew needs to be disconnected regularly. For general maintenance as well it should be a doddle, screw it out, pull the slide off the saddle for maintenance, then slip it all back together again. As mentioned, slacken up all your adjustments and it should pop right back in, making sure your gib strip is the right way round/fitted correctly(some have locating dimples). |
Nicholas Farr | 25/04/2011 10:48:47 |
![]() 3988 forum posts 1799 photos | |
Chippychap | 26/04/2011 09:03:15 |
![]() 11 forum posts | Bless you all for that.
Does the leadscrew engage in the saddle as pictured or is the lead nut the other side of the block?
Nicholas Farr | 26/04/2011 09:37:54 |
![]() 3988 forum posts 1799 photos | Hi Chippychap, the nut is embeded in the saddle directly in front of the the screw as in the picture above.
Regards Nick. |
Chippychap | 26/04/2011 09:37:58 |
![]() 11 forum posts | DONE.
![]() I mistook close fit with "That does not slide off"
You guys and the lathe have taught me valuable lessons. Thank you. |
