Hipp Pendulum Clock
Stephen Mackie05/03/2011 04:33:24
7 forum posts
As a young lad back in the 1950's I read an article in one of the magazines about the construction of a one second Hipp pendulum clock using the wheel work of a cheap alarm clock. I am certain the someone of my vintage must know about this and could help this old Aussie with the plans.
I enclose my mail address:
Steve Mackie
11 Huxley Avenue
MULGRAVE
Victoria
Australia
NJH05/03/2011 14:14:54
2314 forum posts
139 photos
Hi Steve
I don't have access to this particular article but I do have a book by John Wilding - How to make a Battery Powered Electric Clock . This operates on the Hipp Toggle principle.
There is a link Here
This is an unusual clock in that the pendulum moves from back to front rather than left to right. The clock is a modification of the Hipp known as the Scott clock. It seems that the Scott version was made by the Ever Ready Battery Co in the early 20th Century. I have seen an example at Castle Drogo in Devon.
I have the book, I have all the materials and one day I might even get round to making it !
This may not help your search but may be of interest.
Norman
Niloch05/03/2011 14:36:19
371 forum posts
Can't help you directly I'm afraid but it's possible you might find this link of assistance.
Richard Parsons05/03/2011 14:49:24
645 forum posts
33 photos
Hello there
I think you will find what you want here It dates back to 1948 and is by artificer.
Hope it is what you want
Dick
Richard Parsons05/03/2011 15:06:54
645 forum posts
33 photos
Hello again Steve
I only found half of it but here is the whole thing
It looks a nice little project.   By the way old Artificer got something wrong Archimides -a mate of Old Doggyknees- did his streak in Syracuse not Athens.  But i think the rest of it is OK.
Dick
Edited By Richard Parsons on 05/03/2011 15:07:32
Edited By Richard Parsons on 05/03/2011 15:16:51
Buster10/03/2011 14:49:25
20 forum posts
Hi Stephen, i remember the exact article you are talking about but i am not sure if i still have the notes etc, i will get back to you and let you know, cheers David
Buster11/03/2011 13:07:35
20 forum posts
Hi Stephen, try your library service for these books, electric clocks and chimes isbn 0 85242 474 or Electric clocks-principles-construction and working ( no isbn No) but it was printed in 1920 as a series of Cassels work handbooks, cheers David
John Haine11/03/2011 13:18:24
5563 forum posts
322 photos
Er, the Eureka is a balance wheel clock and doesn't use the Hipp toggle principle - see http://www.hvtesla.com/masters/po36_toggle.html for a description of how that works.
Stephen Mackie14/03/2011 07:52:50
7 forum posts
Hello David
Thank you so much for all your research efforts. I will certainly,follow them through.
Cheers, Steve
Stephen Mackie14/03/2011 07:55:05
7 forum posts
Hello John
Thank you for the information on the Hipp cycle and for understanding what I was talking about
Cheers, Steeve
Richard Parsons14/03/2011 12:48:19
645 forum posts
33 photos
There is another form of the Hipp escapement. This gives an impulse to the pendulum when the amplitude of its swing has died down to below a set limit. The ‘scape wheel is cut with both a primary and a secondary cuts. The primary cut is the normal cut for a Hipp pull escapement. Close to it is a secondary cut which is on a smaller diameter than the first (primary cut). As the pendulum amplitude dies down the escapement fails to hook in to the primary cut, so it falls into the secondary cut and rotates the wheel a little less BUT by lowering the ‘hook arm’ it closes the circuit to the Power Magnet which then boosts the now disengaged free swinging pendulum. The advantage of this is that the impulse is given to the pendulum when the pendulum is disengaged. It has at least half a beat to re stabilise. As the hook arm runs forward for another pull on the ‘scape wheel, it lifts and opens the magnet circuit.
The advantage of the GPO type Hipp trigger is that it is easier to adjust. The GPO clocks were fitted with a ‘de-bounce’ system which stopped the clock from getting into a ‘bounce’ situation.
Magnets for Hipps have to be made of metals which demagnetise easily. Old transformer cores are probably the only source of this stuff.
