Crank Diameter
Alan Worland15/02/2011 21:26:53
247 forum posts
21 photos
I am machining the crankshaft for a Stuart Turner No 4 the drawings of which suggest the main bearing and big end diameter is 7/16
There is plenty of material to come off that I have decided to make these bearing surfaces 0.500 - the main bearings and big end will accomodate the extra.
Has anybody else done this and might there be a problem I have not thought about?
John Olsen16/02/2011 05:21:43
1294 forum posts
108 photos
It will not cause any problems, and is a good idea if the engine is likely to do any hard work. The Stuart engines generally are semi-scale, eg they are not scale models of a particular prototype, but are proportioned as if they were. So the journals are smaller than they would be if the engines were intended for hard work.
regards
