Stuart Turner Castings
Alan Worland19/01/2011 20:55:32
247 forum posts
21 photos
I am gradually working my way through some of the larger castings and have found them to machine well with not too much to take off - until I came upon the cylinder!
I have been removing something in the order of .030 - .060 off the various faces but the cylinder bore which finishes at 1.500 started off with a cast bore of about 1.150!!
Thats an awfull amount of cast iron to remove - I had it all bolted to the large faceplate which required a consierable amount of balancing so I was keeping the speed low and as a consequence it took ages.
Is this done for a reason?
Terryd20/01/2011 08:45:41
1946 forum posts
179 photos
Hi Alan,
Which model is it you have? Stuart make a lot of kits.
regards Terry
Edited By Terryd on 20/01/2011 08:46:35
Alan Worland20/01/2011 22:19:37
247 forum posts
21 photos
Hi Terry,
It's the No4 engine I have, it a '4' cast in the cylinder so I guess it's the right one.
I initially thought it might be a common casting to be used with other designs?
Just seems a lot of material to remove, I have left it 0.002 under for a final hone.
Alan
