Ramon Wilson | 03/01/2011 18:10:29 |
![]() 1655 forum posts 617 photos | Hi all,
A couple of months ago I was contacted by a local resident of my village with regard to a triple expansion engine built in the nearby town of Beccles in Suffolk (UK) at the turn of the 20th century - 1903 to be precise.
The firm was called Elliot and Garroods and they produced this engine which they termed 'Special Triple Expansion'. 'Monkey' was a local colloquialism.
This engine had two cranks and the HP cylinder was postioned above the IP both appearing to have piston valves with a slide valve on the LP. These valves were driven by a rocker arm driven by Stephenson's link off a single set of eccentrics at the front of the engine
So far we have managed to find four differing photographs of this engine and the overall dimensions but little else.
We are aware of the Sovereign model engine sold by Reeves which has a similar layout but the 'Monkey' is rather unique in that the flywheel is between the cylinder centre lines and apparently acts as the intemediate crank web.
It is this feature, and the main bearing layout that we would like to obtain more information on
If anyone knows of any reference to this type of engine we would be very pleased to hear from them.
Yours hopefully - Ramon
Diane Carney | 04/01/2011 15:48:11 |
419 forum posts 11 photos | Hi Ramon I am quite interested in this conundrum! Roughly what size of engine is it? Is it an engine in situ - or a model that you are referring to? What is the flywheel diameter, approx.? Curious also about the Stephenson link which suggests it is a reversing engine so I am wondering what was its duty? Possibly winding, or rolling? It is certainly an unusual design. You say the HP is above the IP but are they in line (parallel)? Could you possilby scan and upload any of the photographs you have? Regards Diane |
Ramon Wilson | 04/01/2011 17:55:25 |
![]() 1655 forum posts 617 photos | Hullo Diane,
This engine was developed by E and G to power small fishing vessels. The idea was evidently to shorten the length of the engine in order to increase the fish hold length. Apparently it was very successful and was fitted to many vessels though whether that extended to beyond the fishing industry we are not sure.
Unfortunately despite a considerable fishing industry here in the area (Lowestoft/Gt. Yarmouth) there is very little information on it. I have emailed Anthony Mount via the editor in the hope his vast knowledge may be able to shed some light but not heard anything yet
The person who contacted me, now in his seventies, served his time with E and Gs but obviously well after these were produced. It is our intention if sufficient information can be gained that, with local interest in mind, a model will be made - though Phil is considering making something larger to power his small steam boat. It is hoped that shortly we can meet someone who, now 96!, remembers working on them.
So far we have collated four different images and the overall dimensions - they were made in three sizes apparently but the catalogue image we have only gives two the larger being 9 3/4 x 15 x 22 witha 16" stroke, however RH Clark in his book Steam Engines of Suffolk gives the largest as 9 1/4 X 15 x 26 by 16" stroke.
The valves are worked by a rocking lever moved by the link ie. the valve rods are isolated from the link and as you can see the link is at one end only. (The 'front' of the engine as stated previously refers to its position in the boat)
What makes this engine unusal is that the cranks are set at 180 degrees with the flywheel set between and evidentally acting as the central web - this at the moment is a big grey area as none of the images give any indication as to how the crankshaft was supported in the bedplate - incidentally the flywheel diameter is one of the few known dimensions we have - 2'6" - but the width is unknown.
Phil is currently producing a set of basic layout drawings from which we hope to flesh out the design but at the moment we do not wish to compromise anything with our own ideas until we have exhausted all possiblities of available material.
This pic of the rear of the engine is from the catalogue and is, we believe, from a photograph taken in the workshop. It is the best of those we have so far
And this view - too dark to decipher much I'm afraid is in the workshop itself and is I think the very same engine from the front end.
I have put this on here rather than by PM just in case it rings any bells with anyone else. If you or others are interested in our progress as it develops we will be only too happy to share it. Hope this is of further interest. Obviously we would like to hear of anything even remotely connected so if anyone thinks they may have something we'd be very pleased to hear from them
Regards - Ramon Edited By Ramon Wilson on 04/01/2011 17:57:57 |
John Olsen | 04/01/2011 19:01:54 |
1294 forum posts 108 photos 1 articles | Hi Ramon, Well, for what it is worth, it appears to me that they have simply used a two bearing layout. This would fit in with the overall theme of trying to keep the length down. In the photo from the rear you can see a box shape in between the connecting rod and the rod taht drives the air pump, this would I think be an oil box on the rear bearing, and the big nut next to it would be holding down the bearing cap. That seems to be in line with the column, I expect there would be another one in line with the column at the front end and that would be all she had. I expect the crank would be short enough and stiff enough for that to be OK. The 180 layout means they only need one set of valve gear for all the cylinders Looks like it will be a lot of fun for the pattern maker and moulder, with that built in condenser and the trunking from the LP exhaust to core out. I have wondered about using a radial gear like Joy or Walschaerts on a marine steam engine to reduce the overall length, at the expense of course of putting the valve chests on the side. With the engine shown they have more than halved the length of the engine compared to a normal triple expansion, plus there is no awkward to reach valve sandwiched in between the cylinders. On the minus side, the 180 crank could be a pain for manouevering, such an engine will mostly reverse when you throw the links over, but the time it sticks on dead centre will be when you are about to hit something. regards John |
Ramon Wilson | 04/01/2011 20:34:04 |
![]() 1655 forum posts 617 photos | Hi John
Yes that's more or less our thinking but having drawn it out unless the flywheel is much wider relative to diameter compared to what it appears - something we can't ascertain as yet - it makes the crank pins set in the flywheel rather longer than you would expect but the wider it is the more weight upon those bearings. We are hoping before too long to begin on a wooden mock up - in the hope that we can see the problems more clearly in 3D.. I suspect the flywheel is probably wider than what we are assuming at the moment - i.e.10".
Because of the 180 cranks the engines evidently had to be barred frequently - the barring mech is that short lever sticking out at 45 degrees.
Phil is in contact with people who can remember them but not any specific details - indeed he remembers one standing in the corner of the same shop in that second image when he began his apprenticeship - it went for scrap! As he says if only he had been aware that sixty years ahead he would have wished he'd paid more attention! Once we feel we have done the best we can I hope to fabricate as much as possible -
castings are just getting far too expensive !
Regards for now - Ramon |
Nicholas Farr | 04/01/2011 21:21:03 |
![]() 3988 forum posts 1799 photos | Hi Ramon, I don't know anything about these types of engines, but just a thought, if it has a wider flywheel than you might expect, could it be possible that it is hollow to keep the weight.down.
Regards Nick. |
John Olsen | 05/01/2011 03:52:39 |
1294 forum posts 108 photos 1 articles | Hi Ramon, Well, the flywheel itself need not be the full width, so long as the bosses for the cranks have plenty of meat in them. It is a while since I have seen the insides of a 650 Triumph motor, as I recall they had the two cranks bolted onto the flywheel. Those were a 360 setup, but the same sort of thing should work for a 180. So the flywheel need not be the full width between the two big end bearings, so long as you build in the strength. I think if it were me designing it, I would have accepted the extra complexity in the valve gear and gone for a 90 degree crank. I would probably also have put in the centre main bearing and used full circle crank webs to regain the flywheel effect, which is not generally very much needed on a marine engine anyway, since you have a shaft and a propellor attached. (It is a handy thing on smaller steam launches, which do tend top run jerky without it, and it is useful to be able to give it a kick if the engine does stick on centres.) The usual thing with a compound is that each cylinder should be producing equal power. That would imply that the load on one big end bearing is twice that of the other. On the other hand, the inertia loads might be similar, since the one big piston might weigh as much as the other two put together. What is the betting that somewhere in the undergrowth one of these is lying around somewhere, waiting to show up just after you have finished a model one? There will be some pretty heroic fabrication work to do too! I rather like the triple expansion engine shown in the Bill Durham steam launch book. It was meant for river work in India in a shallow river, so they put it crossways across the boat, and gave it three shafts, each with its own propellor. The shafts were all linked in the engine with coupling rods. The three cylinders would be at 120 degrees, and the coupling rods would be at 90 degrees. There was a separate Stephensons link for each valve. So there would be lots of bits to watch going around. regards John |
Ian Elliott 2 | 14/02/2019 20:42:09 |
1 forum posts | Ramon. Reviving an old post of yours. I'd be interested if you found out anything more on this? These engines were made by my great grandfather. Having just finished a 1/6 scale capstan, I am looking for a new project but know nothing more about these engines than this thread. |
Ramon Wilson | 15/02/2019 08:41:59 |
![]() 1655 forum posts 617 photos | Hello Ian, this is a surprise! I visit rarely these days, Jason pointed me in this direction but always happy to assist where possible I'm afraid very little more was found out after the last posting. My friend Phil did find another old photo that 'sort' of gave an indication to the valve operating arm but we never did establish the correct layout of the bottom end. That said Phil did an awful lot of work in producing a concept drawing on AutoCad but he suffered computer issues that put paid to that. Sadly Phil died last year with that not quite finished. I think I have copies his files somewhere and what photos, etc he found. If you PM me I will see what I can do for you. You are welcome to what I have as I think without Phil's enthusiasm I'm unlikely to pursue it any further. I try never to make assumptions but I guess your great grandfather would be one half of the company? Incidentally, if you don't reside in the area, the building in that image still stands, the ornate windows still in situ. Very interesting to hear you made the capstan. Regards - Ramon Edited By Ramon Wilson on 15/02/2019 08:43:35 |
