Wolfie | 10/11/2010 20:57:55 |
![]() 502 forum posts | OK can anyone tell me how to rescue blunt drills? |
Digger | 11/11/2010 09:56:49 |
9 forum posts | I have a fixture from draper that allows you to set the angle of the rake for the drill and then you use it against the bench grinder to get a good edge. You can try to re grind a drill by the "Rack of the eye" method but you need a steady hand, it's okay to use that method if need a drill right there and then but it won't really be accurate. The draper fixture is okay and not too expensive and will give a good result once you've got used to using it. |
John Shepherd | 11/11/2010 10:58:50 |
222 forum posts 7 photos | Wolfie
Have a look at this current thread on 'advice on drill sharpening jigs'
Edited By John Shepherd 1 on 11/11/2010 11:09:07 |
