Bernard Owen | 28/10/2010 15:13:47 |
13 forum posts |
Hi, I need a small milling machine for light work, as I have a very limited budget I was thinking of getting a Model Super X1L Mill from Arc Euro Trade, has anybody got any experience of this machine and could give me some advice.
Thanks.
Edited By Bernard Owen on 28/10/2010 15:14:24 |
Bernard Owen | 28/10/2010 15:14:30 |
13 forum posts | |
Greenjob | 28/10/2010 19:30:32 |
7 forum posts 1 photos | Hi Bernard
I bought a Super X1L from Arc over a year ago and although it is a small mill I can honestly say that I have had no problems with it. I also started with a limited budget as I am a beginner at model engioneering (although in my 60's - a late starter)!
I am having a go at building a 31/2 'Greene King' at the moment and so far it has done everything I have asked of it, so If you are only intending to use it for light work then I would think it would suit you just fine. I have no complaints!
Hope this helps in some way.
Phil |
Bernard Owen | 31/10/2010 11:43:57 |
13 forum posts | Hi Phil,
Thanks for the reply, it sounds as if that is the one then, did you buy it prepared or prepare it yourself which is what I'm going to do.
I'm a bit of a late starter myself , I am in my 70's.
Bernard.
Greenjob | 31/10/2010 16:28:42 |
I prepared it myself which was really straightforward. It mainly involved the removal of the x & y tables cleaning same and then removing all the packing and transit grease on the machine,which is quite heavy stuff, and then setting up the tables again. If you would like to let me know your e-mail adress I can send you some photo's of it 'in action' so to speak.
Phil |
Michael Cox 1 | 31/10/2010 19:30:50 |
555 forum posts 27 photos | I have owned an X!L mill for several years. It is fairly robust and rugged. However, you must remember that it is only a small mill with a 150 watt motor. You cannot make massive cuts in steel but what you cannot achieve in one pass can always be achieved with multiple passes. It has proved reliable although I suggest any new owner invests in a stock of replacement fuses since these do blow if you attampt a heavy cut.
I have made a number of mods to improve the performance and versatility of the machine. These are shown here:
At the moment I am working on a motorised drive for the table.
Mike |
