Running problems
martin h g bourn | 11/08/2010 14:55:32 |
1 forum posts | Having built a clock I am having difficulty in getting it to run continuously. The best so far has been 36 hours. Suggestions as to what to do would be appreciated.
Martin H G |
keithmart | 11/08/2010 15:18:19 |
![]() 165 forum posts | Hi
It's easy to build a clock, but a lot harder to make it go!!
Check the running time accurately for a few times and see which gear tooth is a little sticky. If you start running from a constant point, you could use say 12 0 clock for instance, you should be able to work out how much each wheel has moved. those that have done more than one turn are probably OK, then put a pencil mark where the meshing points are when it has stopped. Other things to check are the pinions are not binding and have free sideways movement.
I hope this puts you on the right track
Regards Keith Leeds UK
