John Littler 1 | 24/03/2010 21:56:19 |
6 forum posts | Am building "Little Ben", as serialised in ME some six years ago. The design does not have drive gears, just a rubber belt from the crankshaft to the hind wheel shaft. The intention is to fit gears between one hind wheel and the horn plate, using one countershaft with a compound gear between them, a bit like a Burrell. While I have sorted the DP, centre distances and the ratio, I do not know how wide the gears would have been in full size. Please can someone give me an answer on this point. With Thanks in anticipation |
mgj | 24/03/2010 23:09:00 |
1017 forum posts 14 photos | I don't know what Little Ben is, but my Little Samson is a small type light steam tractor. In 1/4 scale the drive gears are 5/16" and 3/8" wide. That gives a full size thickness of about 1 1/4" & 1 1/2". So whatever that works out in your scale, if we are talking of the same kind of machine?. |
JasonB | 25/03/2010 07:30:31 |
![]() 25215 forum posts 3105 photos 1 articles | My Fowler is 1/6th scale (2") and the gear faces in that are between 3/8 & 1/2 so full size would be 2 1/4 to 2 1/2". Its a larger traction engine than the little samson prototype.
The 1" Minnie in my avitar uses 3/16 wide gears throughout.
Jason |
JasonB | 25/03/2010 08:44:07 |
![]() 25215 forum posts 3105 photos 1 articles | Just seen it on youtube, I would not go much over 1/8" wide, probably could not fit anything wider anyway and its not as though its going to be pulling you along
Jason Edited By JasonB on 25/03/2010 08:45:07 |
John Littler 1 | 25/03/2010 18:51:13 |
6 forum posts | My thanks to JasonB & mgj. The engine on youtube, which I hadn't seen, is not mine; if anyone is attending the "Myford" (no connection) next month, my model will be there, and running on air. The info is very helpful, thank you gentlemen. I think that "Little Ben" is probably based on a larger tractor than "Little Samson", although not an accurate model of anything in particular, so I reckon I shall go for 1/8" wide, which in 1:24 equates to 3". JasonB is quite correct, it will only be pulling itself, but still needs to "look right". I have gone for 32DP, with a ratio of 19:1. The ratio is a bit higher than the "low" gear on a Burrell mentioned by Martin Wallis in ME 27/2/2009, and is the result of the available gears in that DP, coupled with the centre distances on the model. |
