2" Fowler Cylinder
DRG MIMechE19/01/2010 00:28:43
6 forum posts
Hi
Has any body machined the new cylinder from M.J.Eng ?
The anulus is part of the casting but only runs half way round when you come to drill the two holes from the regulator chest 3/16" from the drawing only one hole enters the anulus.
I spoke to MJ and they said the casting had changed but were not sure what could be done and would get back to me.
I could only think the anulus would have to be machined out all the way round or maybe a bigger hole in the regulator chest. The old casting i believe you had to machine the anulus in anyway.
JasonB19/01/2010 07:49:25
Drill two holes on the oposite side to the valve chest, one to the front of the regulator the other to the rear.
You can see how I did Mine including the one that I stopped part way through drillingas I felt it was going to cause problems.
I did turn a shallower annulas on mine to reduce the friction when inserting the cyl liner, about 0.004"
I'll pm you later, off to work now
Jason
DRG MIMechE08/06/2010 19:07:33
6 forum posts
Hi >>
I was hoping that I could get some more advice on the 2" fowler cylinder. I drilled the 6 holes at each end which break through to the inlet ports in the valve chest, and the drawing says to recess them 3/32 on the top of the cylinder.  The cylinder cover has a 3/32 lip which locates into the bore, this seems to close off the recess. Any help would be appreciated.>>
JasonB08/06/2010 20:10:43
You need to mill away part of the spigot on the cylinder covers to allow the steam to flow through. I think I did mine 1/16" deep and 1/4" in from the edge
Jason
DRG MIMechE09/06/2010 22:43:23
6 forum posts
Thanks for your help Jason i will try that.
