Britannia Boiler
Britannia Boiler
Rick Moore20/11/2009 17:01:02
8 forum posts
15 photos
Has anybody locally to me (Hull) made a 5" gauge britannia boiler to the Norman Spink design. I need to beg, borrow or hire any flange forming plates you may have made. Alternatively has anybody had sucess by using a couple of thicknesses of thick MDF for a former?
Tony Martyr24/11/2009 10:25:25
226 forum posts
45 photos
Hell Rick
First answer is 'No'
However having just used a block of hardwood as a former material I rather doubt that MDF will work well - Based on recent experience I think the difference in hardness between MDF and rapidly work-hardening copper sheet is probably not sufficient to prevent significant former damage however 1/16 steel sheet on top that forms the start of the radius may keep the edge shape better.
Rick Moore24/11/2009 23:01:48
8 forum posts
15 photos
Thanks for the reply. However I have just had a go this evening with the MDF method and it is ok. I made the largest plate, the throat plate, and took it easy with hammering. It took four heating sessions and although I will not need another boiler the 25 mm MDF former and backing plate would easily stand up to another go. I gave it a generous radius of about 1/8" round the edges and beat the 3mm copper over with a small block of steel. 25mm MDF cost only £4.18 at B+Q for a 2' x 4' offcut and was easy to shape too.
