Broken spindle
david lockwood | 06/10/2009 23:27:14 |
41 forum posts | Hello chaps unfortunately I had a dig in whilst parting on my Myford ML7 and now when I try to take a cut deeper than 25 thou ish the pulley spins round but the gear it drives stays still. I can not see a way to fasten them back together without damaging the gear. Is there a way this can be fixed? Any help will be greatly appreciated
With thanks in advance (optimistically) David |
mgj | 07/10/2009 18:20:15 |
1017 forum posts 14 photos | Ring Myfords and explain the problem. They can give you an answer on the spot, and will have parts on the way inside a day. (take credit cards too!) 0115 9254 222 will get you reception. Might be worth slackening the belt a little? And grooving the top face of the parting tool.? Must have been quite an impressive jam up? Edited By meyrick griffith-jones on 07/10/2009 18:26:26 |
JasonB | 07/10/2009 18:34:45 |
![]() 25215 forum posts 3105 photos 1 articles | From the Lathes.co.uk site, may be of help
"Unfortunately the assembly does contain a weak point: the 3-step aluminium pulley is only pressed onto the sleeve - and it is not unknown for it to become loose and rotate. However, if the assembly is stripped, cleaned and the pulley secured onto the sleeve with a slight smear of low-strength Loctite all will be well.
" Jason |
david lockwood | 10/10/2009 23:41:28 |
41 forum posts | Thanks very much. Now I just need to disassemble the thing |
