How to take up wear in the older 'expanding' type clutch
IanT | 09/06/2009 14:42:28 |
2147 forum posts 222 photos | My old Super 7 (the type with the oil window in the headstock) had had a hard life before she came to me. None the less with a little care and attention it's been a very useful tool and I'm not too bothered about the inhertited dents etc.
However, I've now adjusted the clutch a couple of times but it's starting to slip again. I don't want to overtighten the adjusting grub screw as this is the clutch model that Myford no longer have spares for. There is an expanding cylinder inside the countershaft/clutch drum and I suspect that the two friction surfaces are getting a bit worn by now.
I wonder if anyone has sucessfully stuck (epoxied) a shim (brass or tinplate) to the expanding cylinder to take up the wear - as these are normally non-bearing surfaces. This would mean less need to tighten the adjustment screw. Any other ideas would also be welcome however. For instance is there anything in old ME's about this?
DMR | 09/06/2009 18:35:18 |
136 forum posts 14 photos | Ian,
I have SK1711 as original with roller bearings. I fitted a backup grub screw behind the main one (BSF) to lock the position as I descided it was probably working its way out. No more troubles.
Originally (3 years ago) I had slip as I had set it up. descided I was probablly being too soft and it was wearing out the clutch because of slip. the tighter you make it, the more you think the two bits holding the roller bearing in the handle are going to give up, but it all seems OK. Myford still have those bits as they fit the clutched ML7, but not the bearing which can be had from elsewhere anyway.
Good luck anyway,
Dennis
IanT | 09/06/2009 19:29:49 |
2147 forum posts 222 photos | Thanks for the feedback Dennis - I may try that and see if it solves the problem.
Regards, Ian
