Chris | 21/05/2009 22:55:12 |
87 forum posts 13 photos | Does anyone know what the thread is on the posilock milling chuck (mt 3)? I have a Clarke 500 lathe and need to make a draw bar.
Chris.
David Clark 1 | 22/05/2009 07:34:41 |
![]() 3357 forum posts 112 photos 10 articles | Hi Chris
What is the internal diameter of the thread?
Usually drawbars are 3/8 Whit or 10mm.
The Clarke is more likely to be metric so I would try a 10mm bolt in it first.
If that fits, buy a bit of 10mm studding (threaded rod) from B&Q.
Larger Bridgeport type mills are usually 7/16UNF.
regards David
Richmond | 22/05/2009 11:20:37 |
![]() 73 forum posts 632 photos 64 articles | Hi,
From memory, some of the MT3 chucks have an M12 thread for use as a drawbar.
A quick call to Chester should resolve this for you.
Rgds
Chris | 22/05/2009 22:07:20 |
87 forum posts 13 photos | Hi David and Richmond,
Thanks for your help. Turns out to be 100 but not the pitch of standard studding. Found a bolt at work ( I'm the maintenance man at a lead mining museum, how obscure can you get) that fit and cut,sleeved and welded it to the Clarke drawbar. Success. plus a lesson learned,10mm is not always what you think!
Thanks again, Chris.
GarethP | 23/05/2009 09:51:14 |
5 forum posts | If its a old Clarkson posilock it'll be whit - I took mine to the local engineering merchant and told them I thought it was 3/8 whit, they then produced a length of metric stud which did screw in but rattled about - I insisted on a piece of whit stud and it fitted perfectly. |
