Juddery action
Ian Richards 4 | 10/09/2023 07:30:09 |
20 forum posts 8 photos | Good morning folks. I have a rather troublesome 12" Southworth pump in my 16 ft steam launch. I obtained the pump from Keith Appleton (Mainsteam) and it was superbly made by Don English, so I have no doubts as the the quality of it. The pump can be very erratic in use. Sometime it will work perfectly and then all of a sudden judder and stop or just stop. Sometimes it sounds like the pump it not completing a full stroke properly. It has been suggested that there is an air lock. I know nothing about these pumps so wouldn't know where to start ! There are no drain cocks fitted. I added a drain cock to the steam line adjacent to the steam chest to help remove any condensate.Apparently Southworth pumps rely on seepage through the glands to drain. Mmmm ? I have fitted a displacement lubricator. Any advice gratefully received. Fortunately I do have two other methods of getting water into the boiler !!! Many thanks. Ian |
Brian Baker 1 | 10/09/2023 07:48:36 |
![]() 229 forum posts 40 photos | Greetings Ian, although I have no experience with the Southwold range, I have built a number of this type of pump, as well as operating the "full size" versions. I would say that they all can behave as you describe, but the biggest single item that does need care with single cylinder pumps is lubrication. If your lubrication system is OK, then look elsewhere, but i have found that lubrication on the steam side to be very important for reliable running. Regards Brian B |
Ian Richards 4 | 10/09/2023 07:55:43 |
20 forum posts 8 photos | Thanks for that. I’m pretty sure the lubrication side is ok. As well as the displacement lubricator there is a mechanical one that feeds the cylinder. I have a steamboat buddy who is an extremely competent engineer and he has the same pump, totally relies on saturated steam to lubricate and never misses a beat !!! |
Ian Richards 4 | 10/09/2023 09:07:04 |
20 forum posts 8 photos | Here's a link to a video of my pump **LINK** |
Martin Johnson 1 | 10/09/2023 15:47:00 |
320 forum posts 1 photos | Ian, I have built my variation on the Southworth and run it this season on my steam lorry at 160 psi. A few bits of experience I have gleaned:
The pump will run very evenly on air against no load (just like KA's example). On steam, even when warmed up it takes a few strokes to get into it's stride when you open the steam valve, but once properly warmed through is OK, but never as even as on air. I think this problem is likely to be more marked for you as a boat is unlikely to be running the superheat that I have. An ex engineer on the Waverley tells me that they can be temperamental in full size. He recommends opening the steam supply valve when you light the fire and just let the pump warm up with the boiler, you will soon know when the pump is running from the "clonk - clonk". I have tried this approach and it certainly has some merit. My modifications to the design were driven by two thoughts:
You can see more detail about the pump on my Flickr pages of the steam lorry build here: The Weir pump album is 2 row 3rd from left. Hope that helps, PM me to compare notes if you wish. Martin |
Ian Richards 4 | 10/09/2023 17:50:11 |
20 forum posts 8 photos | Hi Martin. |
duncan webster | 10/09/2023 18:40:44 |
5307 forum posts 83 photos | Where's the viaduct, Calstock? |
Ian Richards 4 | 10/09/2023 18:52:21 |
20 forum posts 8 photos | Indeed it is My mooring is adjacent to the viaduct |
Ian Richards 4 | 11/09/2023 20:01:11 |
20 forum posts 8 photos | Martin. Thanks again. |
Martin Johnson 1 | 12/09/2023 13:00:16 |
320 forum posts 1 photos | Glad to be of service, Ian. I have not yet tried restricting the exhaust, but I read that you can explore really slow running with it. Thats a bit tricky to arrange a control in the cab! Martin |
Ian Richards 4 | 12/09/2023 13:05:23 |
20 forum posts 8 photos | Martin. BTW. Keith Appleton doesn't agree with restricting the exhaust, but it does work !!! Thanks again. Ian |
