Oil equivalents for Gargoil (Gargoyle) DTE 797
Daedalus29/08/2023 19:56:24
30 forum posts
Hi all,
Does anyone know what the equivalent of Gargoyle DTE 797 might be. I think it was an old Texaco oil. The milling machine it is for was built in 1966 in Italy. I have not been able to find anything at all about what it might have been.
Cheers,
Daedalus.
Neil Lickfold29/08/2023 20:49:44
1025 forum posts
204 photos
I am sure, that the 797 oil is a turbine oil and ISO32 grade oil. We use DTE ISO32 oil for the hydraulics and use 68 slideway oil for the oilers, except for the DMG mill, that uses a special grease for the linear rails. The Mobil 732 for example, is used in turbine type oil compressors and will replace what you have been using. Talk to your Mobil oil rep or local distributor , and they will give you the advice you really need.
DC31k30/08/2023 19:50:22
1186 forum posts
11 photos
'Gargoyle' looks to have origniated with the Vacuum Oil Company:
https://en.wikipedia.org/wiki/Vacuum_Oil_Company
subsequently owned by Mobil (not Texaco).
However, in here (page 18):
http://www.gannonoils.co.uk/images/stories/Texaco-Equivalents-list.pdf
Texaco list their own equivalent to Mobil DTE 797 as 32 weight hydraulic oil, as suggested above.
