Tony sacc | 29/08/2023 07:39:55 |
69 forum posts 74 photos |
A very fiddly process using the tiny adjusters, so I built this cable splitter and replaced the twin cable throttle with a single. The splitter body is aluminium bored 14mm and threaded each end, the slide is brass and the end caps are aluminium. Picture was taken before I slit sawed cable entries. When finished I plugged the holes in the end caps, assembled the unit and dunked it in my anodising bath. The finish came up rather nice. Rather than have a splitter flopping around inside the tank tunnel, I opted to fix It to the right top engine mount. I spun up some 3mm nipples, fixed them to the cables and dunked them in my solder bath. To fix the cable to the carbs and allow for butterfly adjustment, I made a couple of brackets and spun up an elongated stainless adjuster. Yes, there is a lock nut for the adjuster, just not assembled in the picture. This mod made syncing carbs a breeze. Later on I binned the carbs, bought a couple of VM34 roundside's and installed them on custom manifolds. The carbs came with a small plastic splitter, but the round slide cable pull is quite a bit longer than the BS38 cable pull, so, the splitter didn't have enough pul, it I may make a splitter for the new carbs later on. Edited By Tony sacc on 29/08/2023 07:43:50 |
John Doe 2 | 29/08/2023 10:15:23 |
![]() 441 forum posts 29 photos | Another very nicely made gadget ! Would there ever be any danger of the internal slider sticking in the bore owing to corrosion, and jamming the carbs open? (I note the O rings on each screw-in component, but moisture could travel down the Bowden cable from the throttle grip end). Did the unit operate dry or did you lubricate it? . Edited By John Doe 2 on 29/08/2023 10:17:21 |
