Steve Crow | 25/08/2023 18:13:19 |
429 forum posts 268 photos | A few weeks back, I asked for help identifying some small drill presses. The provenence of the smaller one remains a mystery, but I decided to refurbish it and put it to use. It's not finished yet, this is just the first time I've assembled the major parts. I still have to make an ER8 spindle and a few other bits. There will be a small box on the base plate with on/off and light switches and sockets for power and foot pedal speed control. Eventually I'm going to paint the castings and base plate in a cream enamel. Steve Edited By Steve Crow on 25/08/2023 18:37:17 |
Steve Crow | 25/08/2023 18:20:38 |
429 forum posts 268 photos | The counter pulleys are mounted on a sliding knuckle joint so I can adjust the height and distance. The spring damper is intended to help with belt tension. I got the idea from a Luger pistol breech mechanism.
Dave Wootton | 25/08/2023 18:25:39 |
505 forum posts 99 photos | Lovely work Steve, turned that into a very nice, and useful machine, like the novel tensioning arrangement. Dave |
Steve Crow | 25/08/2023 18:27:28 |
429 forum posts 268 photos | The fine adjustment on the table should make an effective depth stop. I'm hoping to use this for consistent depth countersinking and screw counterboring (horological size stuff) |
Steve Crow | 25/08/2023 18:36:10 |
429 forum posts 268 photos | Dovetail motor mount for quick tensioning adjustment. I need to make a locking lever for the central gib screw. The motor plate is detachable because I intend to use the whole assembly on another machine as well. The bottom of the motor plate will be lined with a 1/16" rubber sheet to cut down on the vibes. |
Steve Crow | 25/08/2023 18:46:46 |
429 forum posts 268 photos | With LED ring light. You can just swing it out of the way for changing tools etc. as it sits on a friction collar. I also want to use this for spot drilling small parts after marking out for depthing, for example and I need all the light possible. This is meant to be very much an "analogue" machine. No measurements as such but everything done by feel and sight. |
Michael Gilligan | 25/08/2023 19:43:22 |
![]() 23121 forum posts 1360 photos | Very nicely done, Steve MichaelG. |
Steve Crow | 24/09/2023 16:02:44 |
429 forum posts 268 photos | Finished this at last apart from the drive belt. Very pleased with the paint finish. I used Paragon Old English White and clear laquer. Started with etch primer and 4 coats of Paragon high build undercoat. And a lot of rubbing down. Steve Edited By Steve Crow on 24/09/2023 16:03:42 |
Dave Wootton | 24/09/2023 16:33:31 |
505 forum posts 99 photos | Lovely work Steve, seems a shame to get it all mucky drilling holes with it! |
Nigel Graham 2 | 24/09/2023 18:18:01 |
3293 forum posts 112 photos | Beautiful work worthy of the original construction! I don't think it'll get that grubby, Dave. Steve's making clocks not modifying steam-locomotives, with it! |
Michael Gilligan | 24/09/2023 20:45:21 |
![]() 23121 forum posts 1360 photos | That is delightful, Steve MichaelG. |
