3D Printed Hand Plane
Martin King 219/08/2023 14:11:17
1129 forum posts
Hi All,
I recently came across this rather unusual small cast iron hand router plane with 4 blade positions; I suspect that this is user made and have never seen one before. No makers marks anywhere on it.
I think it is rather a nice take on the Stanley 271 and Record 722 models.
I decided to have a go at making one (or more!) using my limited Fusion 3D skills. It turned out to be a bit harder than I had at first imagined but I learnt a lot on the way. Particularly use of the Align and Combine tools.
I still have a lot of trouble getting the correct build sequence in the timeline.
Here are the first two prints after several aborted prototypes:
Just finished a run of 8 sets of brass bushes to be a tight fit in the base; scored the sides with a Dremel to help key the Loctite fixing.
Still pondering the best way to make the cutters;
Should I A: make the cutter tips separately and weld them to a M steel shank?
or
B: make the whole cutter out of tool steel rod and "forge" the end and bend?
Suggestions welcome!
Cheers Martin
File Handle19/08/2023 17:01:47
250 forum posts
I have made similar, but cruder router planes with ground allen keys as the blade.
Dave Wootton19/08/2023 18:36:02
505 forum posts
99 photos
Paul Sellers on Youtube has some information on router plane use and making, he shows one where he did indeed use an allen key for the blade. Not a router cutter but I have bent and "forged" the end of some silver steel to make an internal hollowing out chisel for hardwood and despite using very unscientific methods it did cut quite well.
One warning Paul Sellers videos are addictive.........
Bazyle19/08/2023 20:16:45
6956 forum posts
229 photos
AKA "Granny's tooth plane" I think.
ega19/08/2023 22:58:14
2805 forum posts
219 photos
Or "old woman's tooth".
Nigel Graham 220/08/2023 09:11:39
3293 forum posts
112 photos
Welding a tool-steel to mild-steel may work but risks a brittle weld.
As you've made the cutter-holder cylindrical, the forged form may be easiest but you could make an insert-tip from gauge-plate, oil-hardened and tempered; screwed to an inclined, rectangular rebate milled in the end of a mild-steel holder.
Martin King 220/08/2023 09:25:26
1129 forum posts
Nigel,
I take your point about a brittle weld, (especially with my welding skills!)
Some of the larger cutters for the Stanley No:71 Larger hand routers have one blade with a detachable tip to make honing easier.
The standard cutters for 271 & 722 planes are just bent (as is the original cutter for this one)
I think I will take a look at re purposing an Allen key as my first thought, thanks for that idea guys!
Will keep you updated as I progress.
Cheers, Martin
Ian Burks20/08/2023 09:50:45
3 forum posts
I made a granny's tooth from offcuts of oak. My design is different in that the blade is straight but at an angle. This makes for a very rigid tool as the blade is supported right down to the sole plate.
For the blade, I bought an old chisel (with a cracked wooden handle) for £1 but the blade was marked "Sheffield Steel". I cut the tang off & welded a short piece at rightangles. This engages with a knurled thumbwheel for fine depth adjustment. The weld is well away from the business end - where the tang used to be. In addition, sharpening is easy - like a regular chisel.
