Member postings for Ian Burks
Here is a list of all the postings Ian Burks has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco WM250V : Tray Cleaning Questions
21/08/2023 13:57:50
I place a couple of layers of newspaper in the tray beneath the bed & wrap the swarf up & discard every once in a while.
A rectangular cutout at one end of the sheet allows my newspaper to cover most of the drip tray, even alongside the headstock. I can cut a full newspaper in one go & use 2 or 3 sheets at a time.
This works for me as I don't use coolant other than dripped from an oil can.
Thread: 3D Printed Hand Plane
20/08/2023 09:50:45
I made a granny's tooth from offcuts of oak. My design is different in that the blade is straight but at an angle. This makes for a very rigid tool as the blade is supported right down to the sole plate.
For the blade, I bought an old chisel (with a cracked wooden handle) for £1 but the blade was marked "Sheffield Steel". I cut the tang off & welded a short piece at rightangles. This engages with a knurled thumbwheel for fine depth adjustment. The weld is well away from the business end - where the tang used to be. In addition, sharpening is easy - like a regular chisel.
Thread: Track circuits
15/07/2023 18:47:31
I haven't see the article you refer to however, you are correct that the principle of operation is that a proportion of the track circuit current is diverted via the locomotive & carriage wheelsets. If correctly setup, the track relay should drop indicating that the track section is no longer clear.
It is also true that part of the current will leak via the ballast & sleepers. As you say,this depends on the weather, the amount of oil & cinder in the ballast, the amount of water dripping from the roof of tunnels, etc. Remember also that Concrete sleepers are full of rebar. This all needs to be taken into account when setting up the track circuit. Typically the ballast resistance (on a standard guage track) could be between 2 Ω when wet to 100Ω when frozen for a track section up to 1000ft long.
However a track relay is a sensitive device. Its DC resistance might be only of the order of 5-10 Ω. Typically this type of relay may require 100-140mA to energise. It is the current flow that creates the magnetic field but, from Ohms law, you can see that the relay will energise or "pick" with only around 0.5V across its coil.
Once the armature has pulled in, the air gap in the magnetic path is smaller & therefore it will remain energised even if the current reduces slightly. This is the Hysteresis. Typically the pickup voltage might be 0.5V but the drop-away voltage might be 0.35V.
When testing a track circuit, a variable resistor is connected across the rails & reduced until the track relay drops. This is known as the "drop shunt" value. Then the test resistor is set to zero & increased until the relay just picks. This is known as the "pickup" or "prevent shunt". As a rule of thumb, the higher should be at least 133% of the lower. In addition, a shunt of 0.5Ω at any point along the track should drop the track relay. This will generally give a good compromise between reliably detecting a clear track while coping with varying weather & track conditions.
