Martin Shaw 1 | 07/08/2023 16:06:45 |
185 forum posts 59 photos | I have to make a siphon from 1/16" pipe bent around a 1/2" former. Should I anneal the pipe before bending, personally I feel so but guidance would be welcome? Regards Martin |
Bruce Voelkerding | 07/08/2023 16:12:24 |
77 forum posts 7 photos | a couple of Questions - o is it Copper Tubing ? o how many Turns will the Siphon have ? o are you intending to use a grooved Former and Roller ? |
Harry Wilkes | 07/08/2023 16:47:04 |
![]() 1613 forum posts 72 photos | Not long done one for Stuart Boiler, I annealed mine simply due to silver soldering pie fittings on it I then bent it around a drill. H |
bernard towers | 07/08/2023 17:27:16 |
1221 forum posts 161 photos | Always anneal before bending the tube will work easier and the inside and outside of the bend will more readily contract and expand. |
Martin Shaw 1 | 07/08/2023 22:05:18 |
185 forum posts 59 photos | Bruce Copper, 2 turns, no just a piece of bar. Harry and Bernard Thanks, you have confirmed my thoughts. Regards Martin |
Martin Shaw 1 | 13/08/2023 11:40:57 |
185 forum posts 59 photos | Just to finish this off. I made one that would have been fine except it was blocked by excess solder, a second more careful attempt works perfectly and bending was much less scary than I imagined. Regards Martin |
Harry Wilkes | 13/08/2023 16:07:09 |
![]() 1613 forum posts 72 photos | Posted by Martin Shaw 1 on 13/08/2023 11:40:57:
