Stuart No.9 Governor
Spring belt slippage
Sanjay Fernando16/05/2023 22:59:14
3 forum posts
This is my first ever post and I'm relatively inexperienced having only ever built a Stuart 10v and recently a no.9; forgive me if its a stupid question.
I have just finshed machining and fitting the governor to the no.9 with the spring belt provided. I'm getting slippage and cannot work out if its simply a new spring belt stretching and requiring periodic adjustment until the correct tension is reached and the stretch has been eliminated or if there is problem around the governor pulley mounting on to screw spindle?
Any advice great appreaciated
Jim Nic17/05/2023 10:11:47
406 forum posts
235 photos
Hi Sanjay
In my experience spring belts are not the best for transmitting power but the 3 engines that I have using them for the purpose do work OK.
I have no experience of the Stuart No 9 but the first thing I would check is that the governor is free to turn and that there is no binding in the belt run itself.
Hope this helps
Jim
Howard Lewis17/05/2023 16:56:53
7227 forum posts
21 photos
Try increasing the tension (This will mean cutting bthe spring belt and unwinding the uynwanted portion from the "socket"   So don't cut the wrong side of the join!
Sanjay Fernando17/05/2023 17:51:56
3 forum posts
I have gone in order of the replies and thankfully the governor itself spun freely without any undue friction. I have now tensioned the belt again and it all seems to be running smoothly.
I think I was being over cautious with the amount of tension I was putting on the belt having never experienced one before; to a novice and as eluded to by Jim, they do seem a strange way transmitting power
Thanks for replying to my 1st post - I'm sure I'll be back for more ................smiley
Jim Nic17/05/2023 19:19:55
406 forum posts
235 photos
Good to see you now have it sorted and another lesson in your store of experience.
Jim
