Old Hole Plate Questions
Chuck Taper04/05/2023 15:16:46
95 forum posts
37 photos
Into my possession came this.
180, 144,84, 50 holes. & Appears old (see font used in stamping)
It's approx 1/4inch thick - 7inch diameter - bronze.
Any thoughts on the specifics of what this is or what/how it was used.
Could it be specific to clockmaking??
Thanks in advance.
Regards.
Frank C.
Andrew Johnston04/05/2023 17:03:05
7061 forum posts
719 photos
Probably used for direct indexing for gear cutting and similar. The disc looks like clockmaking rather than industrial. I don't know if the nuimbers are common tooth counts for clocks.
Chuck Taper04/05/2023 17:59:38
95 forum posts
37 photos
The three outer rings of holes appear indexed into 12 segments.
The 50 holes ring is indexed into 5 segments.
Regards.
Frank C.
DC31k04/05/2023 18:00:12
1186 forum posts
11 photos
The factors of the hole circles correlate with some time-related things.
180 = 2x2x3x3x5 so it contains 60 (seconds in a minute, minutes in an hour)
144 = 2x2x2x2x3x3 so it contains 24 (hours in a day)
84 = 2x2x3x7 so it contains 7 (days in a week)
What puzzles me is that there is no obvious time-related thing that relates to 50 (2x5x5).
The sub-divisions they have stamped on the circles probably has some significance. For instance, why is the 84 stamped every 7 when it could equally be stamped every 6?
Andrew Johnston04/05/2023 18:56:14
7061 forum posts
719 photos
Posted by DC31k on 04/05/2023 18:00:12:
...why is the 84 stamped every 7 when it could equally be stamped every 6?
Seven is a prime number so can't be factorised?
Bazyle04/05/2023 20:25:08
6956 forum posts
229 photos
10 and occasionally 20 is used for (clock) pinions. Just look for 'wheel cutting engine' and you will see something familiar. Often they only needed a few rows of holes so were not trying to get lots of rows of primes like a dividing head plate, but used a large plate for accessibilty and mechanical advantage.
