Mk1 Myford Super 7 lathe
Oil drip feed
paul sheldon25/04/2023 22:50:24
5 forum posts
Help
I have bought a Mk1 Myford Super 7 lathe and doing a full restoration on it however there is an oil reservoir built into the Headstock. Underneath is a plastic see through lens and a white plastic cup both are broken and needing replacement however there is a brass tube running through connecting both the oil Reservoir and plastic cup which will need to be removed its rock solid so I imagine will need to be drilled out and replaced from the early research that I am doing it would seem a tad difficult to obtain as in no chance
Can someone help me please any help and advice would be much appreciated
Thank you for reading
Paul
not done it yet26/04/2023 08:33:26
7517 forum posts
20 photos
Drilling it out, if necessary is obviously a job while the spindle is separated (or at least the top bearing housing removed) from the headstock.
However, you have a lathe, so that part can easily be made, in the lathe, after the restoration is mostly complete, if necessary?
