Steve Crow | 27/03/2023 18:36:27 |
429 forum posts 268 photos | I want to cut a couple of irregular holes around 2 inch diameter in 3mm ply. I really don't want to buy any tools for this. I have a selection of piercing saws and I don't mind splashing out on some blades that could do the job. Has any one any suggestions for something suitable? Cheers, Steve |
Dalboy | 27/03/2023 18:42:52 |
![]() 1009 forum posts 305 photos | It depends on the ply as some will splinter very easy. A coping saw or fret saw with a very fine blade will help reduce splintering as will applying tape to both sides. If it is a better quality ply then that is not likely to happen as much. I use a powered scroll saw and use tape to prevent the grain on the laminations from splintering and as an added bonus it can also aid when cutting as some act like a lubricant for smoother cutting |
File Handle | 27/03/2023 19:02:28 |
250 forum posts | You can use a fret saw blade in a piercing saw, but the small throat depth will be a restriction compared with using a fret saw. The advantage of a coping saw is that you can turn the blade to go around corners. |
