Dial caliper repair
Allan Webster | 20/02/2023 15:23:28 |
![]() 19 forum posts 23 photos | Attached is a photo of a Dial Caliper that was given to me some time ago minus the lens and with a very dirty face as a result of having been used without a lens. Careful cleaning made it usable (further cleaning threatened to remove surface) before a search for a lens started. Availability, cost the have it fitted etc prompted me to make one. A piece of material clamped between two spoons and immersed in hot water and allowed to cool gave me the right curvature the difficult part was chamfering the edge. |
old mart | 20/02/2023 19:09:15 |
4655 forum posts 304 photos | Assuming that the jaws are closed, the zero can be reset without removing the glass pointer. The pointer spindle is spring loaded against the rack and with a suitable fine probe, you can get it to jump some teeth much closer to vertical. They used to include the little tool with new calipers. |
Baz | 20/02/2023 20:43:15 |
1033 forum posts 2 photos | Get a paper clip, straighten one leg of it and hammer it flat and you have a zero resetting tool. Open calliper to about 1” position and slide tool along top of rack until it engages with dial pinion and re set to zero. A bit of practice is required, you will make it worse before you get it where you want it, I certainly did! |
