Averill water tubes - Bat
Ady118/02/2023 10:53:05
6137 forum posts
893 photos
Spend a day or two on this and there doesn't seem to be much about and to my newbie eye it simply makes no sense
And in 80 years nobody seems to have taken a picture of their work
If the tube runs from halfway along the boiler to beneath the footplate or firebox then is it plugged at the cab end?(must be, right!)
roy entwistle18/02/2023 11:08:32
1716 forum posts
Looking at the drawing I would say no, it is not plugged. Water must flow through it
Roy
Baz18/02/2023 12:44:34
1033 forum posts
The tube is open at both ends, water flows through it.
Martin Johnson 118/02/2023 12:55:22
320 forum posts
The tubes are open. The heat sets up a siphon effect as steam is made, lost up the short leg and replenished with water down the long leg.
Just love LBSC's grasp of heat loss and radiation theory, though.
Martin
Ady118/02/2023 13:32:27
6137 forum posts
893 photos
OMG I've just figured it out
He's describing 2 totally different boilers
The second one is a system I've not been aware of, the tubes dip into the fire and the boiler sits over the firebox...?
So the flue runs under the boiler
Edited By Ady1 on 18/02/2023 14:01:02
Baz18/02/2023 14:09:03
1033 forum posts
Yep you got it ! Other bit you circled in red is possibly safety valve and steam outlet.
Ady118/02/2023 14:10:01
6137 forum posts
893 photos
duh
I've just spent the last 2 days trying to shoehorn those tubes into my loco boiler, I thought they were to increase the heat transfer surface area
There aint much out there on these things, I'm number one on google after 1 day
Edited By Ady1 on 18/02/2023 14:33:47
Nigel Graham 221/02/2023 21:57:36
3293 forum posts
112 photos
The simpler boiler with the thermic siphons was common practice for methylated-spirit (or nowadays perhaps) gas firing, not coal.
You are right in the tubes increasing the heating area.
