Jones and Shipman Sine Vice
Colin Heseltine07/11/2022 22:46:53
744 forum posts
375 photos
I have a Jones and Shipman Sine Vice. Looking at it it appears that the vice assembly is held to the upper pivoting section of the vice by 6 recessed allen bolts. The vice assembly would appear to be keyed to the pivot section. I am wondering whether the vice assembly can be removed so that I could use the sine assembly on its own with a jig plate fitted to it. If I remove the vice assembly will it still just bolt back on and keep its accuracy. I do not want to dismantle it if it will not reassemble accurately. Has anyone ever done this or know whether it can be done.
Thank you.
Colin
Edited By Colin Heseltine on 07/11/2022 22:49:48
Michael Gilligan08/11/2022 07:07:42
23121 forum posts
1360 photos
Given its purpose, and its respectable origin … I would like to think that there will be a couple of dowels in there somewhere.
”Tested to within 15 seconds of arc” has a very nice ring to it !!
http://lathes.co.uk/jones-shipman-general-accessories/
Hopefully there will be someone here that actually knows !
Edited By Michael Gilligan on 08/11/2022 07:13:07
DC31k08/11/2022 08:14:29
1186 forum posts
11 photos
It will always reassemble accurately. It is just the amount of work necessary to make it do so that will vary depending on its construction.
It would be a good idea to sweep it with a test indicator before you disassemble to benchmark its current state. Then do the same afterwards to see if the standard method of reassembly preserves that accuracy.
Colin Heseltine08/11/2022 22:15:51
744 forum posts
375 photos
It appears my mate has the same sine vice. He was happy to dismantle it. Two allen bolts hold the fixed jaw in place and this has a shallow key running across the width of the jaw. The main vice plate is held down by 4 pairs of allen bolts and when these are undone and removed the vice plate can be lifted off the upper moving section of the sine assembly. The vice assembly is located by a wide machined key running the full length of the vice. Slides in nicely without any play.
So the answer to my question is yes it can be dismantled and easily put together, the two keys should ensure accurate registration of the main body and the fixed jaw.
Colin
