ian weeks | 02/11/2022 08:27:38 |
33 forum posts | Dear All, I have decided to try and build a remagnetiser for some old hornby dublo locos I have as well asa Bing alternator I am restoring. One project leads to another! Rather than re invent the wheel I have been reading as much as I can. I have seen reference to an article in ME in the early nineties (vol 177, 3942). I have taken ME since the mid 80's and they are all stored in the loft. Unfortunately I cannot get at them due to the fact my son has crammed it while he has a house extension!!! If any kind soul could scan it for me I would be most grateful and happy to make a donation to a charity of choice. Also If anyone knows of a more modern take I should like to know . Thank you Ian
Circlip | 02/11/2022 10:07:30 |
1723 forum posts | Send your e-mail address via PM. Regards Ian. |
John Haine | 02/11/2022 12:49:26 |
5563 forum posts 322 photos | If you find the Magnetexpert website I think they have neodymium replacement magnets the right size to fit. |
John Haine | 02/11/2022 13:42:34 |
5563 forum posts 322 photos | Here you go... |
ian weeks | 03/11/2022 09:18:42 |
33 forum posts | Thank you ,gentlemen for your help. Especially "circlip 'for the article. I am now in the position having sourced bits and pieces from the workshop and internet to start . I could go down either ME article road, (12v) or capacitor path using circuit from internet. I think will be 1st option but the fly in the ointment is obtaining 2 suitable "bobbins" / coil formers. The ME article uses sheet tufnol (easy) and tube tufnol ( hard to source except in industrial lengths/ prices). I have some 40mm and slightly larger "nylonie" material, fell of a skip decades ago! I could turn it down but not sure if suitable. I assume any non conductive material would suffice. Anyway , if plan A fails can always use bobbins/ coil for a plan B . Thanks again Ian |
John Haine | 03/11/2022 10:29:05 |
5563 forum posts 322 photos | Yes, anything non conductive and sufficiently strong. Paxolin, pcb material with no copper, thin ply. I made a demag bobbin out of a bit of plastic drainpipe and a couple of thin ply cheeks araldited together. Even papier-mache if it's dried thoroughly and impregnated with a resin - https://www.ronseal.com/products/high-performance-wet-rot-wood-hardener/ works well, very thin, soaks in and dries rock hard. Or use that with a stiff card. I still think that replacing with modern magnets would be better, much stronger and resistant to demagnetisation. |
