Dremel 3400 - what threads on tool ends?
lawrence karthauser19/09/2022 12:50:35
2 forum posts
What is the thread on the end of the dremel 3400 flexible extenson>? Wan to mount it in sainsmart 3016 CNC machine
Bosch cannot help me
Thanks
Lawrence
Michael Gilligan19/09/2022 16:55:59
23121 forum posts
1360 photos
dont know
Sounds more like will not than cannot
Sorry … my Dremel is pre-Bosch, so I cannot help you.
I’m sure someone will be along soon …
Edit: __ it might be worth asking Eternal Tools nicely:
https://www.eternaltools.com/blog/complete-guide-to-your-dremel-rotary-tool
Edited By Michael Gilligan on 19/09/2022 17:00:01
Bezzer19/09/2022 18:43:52
203 forum posts
16 photos
I've got a Bosch Dremel 3000 is it the collet thread on flex extension, or the flex to tool body collar thread.?
Collet thread -. I expected a metric thread but it's a weird one, major diameter is 7.05mm, too much to be an M7, and pitch was somewhere between 0.6 and 0.7 thread gauges. Tried a UNF gauge and 40tpi gave a good fit which is 0.635 bearing out the 0.6-0.7 I thought it was.So I haven't got a clue what the actual thread is, anyone else have a clue?.....or is it a Dremel/Bosch special to stop you using other make accessories ?
Extension to tool body - is probably M19 (major measured at 18.65mm) x 2 (spot on gauge).
Another JohnS19/09/2022 20:03:43
842 forum posts
56 photos
From my notes,
Body end thread - 3/4x12 TPI, or 19mmx2mm pitch
Spindle 9/32 x 40 TPI
but check it! My notes may be wrong, or for a different Dremel than you have.
lawrence karthauser20/09/2022 10:46:44
2 forum posts
I found an adaptor for the main tool itself, "Adapter Ø 43 mm 3/4" x 12 pitch (Dremel)"
but I am looking for the outside thread on the far end of the flexible extension.
Thanks
Lawrence
Andrew Entwistle20/09/2022 11:41:40
120 forum posts
218 photos
Hi Lawrence,
I have measured it as 12.5 / 11.1 mm 20 TPI and 60 degree angle, so 1/2" UNF
Andrew.
