Speedy Builder5 | 14/08/2022 18:28:56 |
2878 forum posts 248 photos | Dabling in electronics, Guidance needed (Again). I am playing around with data transfer over wireless , using Arduino UNO and two 5volt to 3volt logic shifters and a 3 volt LoRa RFM98W radio card. In practice, the Arduino could have a USB cable attached to a computer and a 9 volt supply. The Arduino then regulates the supply to 5v and provides its own 3 volt line. 1/ Should I tie the Arduino 3volt output to both the logic shifters and the radio card 3 volt pins. 2/ same for the 5volt rail (excluding the radio card) 3/ same for the ground rail. Thanks in advance Bob
John Rudd | 14/08/2022 19:07:34 |
1479 forum posts 1 photos | I’m not as edjucated as other members. Nor does my noledge equal or better others…. so here goes….
https://core-electronics.com.au/guides/how-to-use-logic-level-shifters-converters/
other members may have a better offering
Edited By John Rudd on 14/08/2022 19:08:08 |
SillyOldDuffer | 14/08/2022 19:09:51 |
10668 forum posts 2415 photos | Posted by Speedy Builder5 on 14/08/2022 18:28:56:
Yes.
Dave |
An Other | 14/08/2022 20:39:29 |
327 forum posts 1 photos | Found this online: "You can use the 3.3V pin to power sensors and modules that need 3.3V power. It can supply about 100 to 150mA of current. The 3.3V regulator is connected to the output of the 5V regulator. Drawing current from the 3.3V regulator will dissipate heat in both the 3.3V regulator and the 5V regulator. This means that if you connect a 3.3V device to the 3.3V pin, then it also limits the maximum current you can use for the 5V modules connected to the 5V pin." Playing about with an nRF24 radio module, I found that the 3.3V supply should be treated with caution - probably depends on where the card comes from. Nowadays I much prefer a separate supply rather than relying on the Arduino itself - I've wasted too much time trying to debug problems eventually traced to the power supply. Consider using an ESP32 module - it can be programmed using the Arduino IDE++, and is native 3.3V, so you don't need level shifters. Hope this is some help. |
Speedy Builder5 | 15/08/2022 06:51:06 |
2878 forum posts 248 photos | Thanks for the advice gents. It looks like I should common the ground for all devices, take the 3.3volt from the Arduino for the level shifters and provide a separate 3.3volt for the radio card so as not to fry the Arduino 3.3v regulator. In which case, not tie the two 3.3volt supplies ? Of course, there are several circuits for the radio card on the net not using level shifters with other comments saying it may fry the radio card and or Arduino. Its a greedy little thing ! Bob |
John Doe 2 | 15/08/2022 07:40:24 |
![]() 441 forum posts 29 photos | I only have a partial understanding of the specific application you are asking about, but it is usually never a good idea to tie "voltage rails" together. Odd things or bad things could happen. By all means tie earths together and, depending on the circuit; zero voltage lines together, but don't tie voltage lines together. The only time you might do so is to parallel batteries, but even that must be done with caution. Something like a transmitter ideally needs its own dedicated supply, to prevent it pulling a voltage rail down and causing problems elsewhere in the circuit. Edited By John Doe 2 on 15/08/2022 07:40:56 |
Speedy Builder5 | 15/08/2022 10:33:32 |
2878 forum posts 248 photos | John, attached is my poor circuit diagram. (Ignore the comments on the diagram) Bob |
Speedy Builder5 | 15/08/2022 10:47:08 |
2878 forum posts 248 photos | John R - thanks for that link. It does explain in simple terms how to link the logic level shifters. In my diagram, I think that the logic level devices and the radio device should have their own dedicated 3.3v supply, and the 5volt supply from the Arduino. Tie the 5v supply and Grnd to the Arduino and the 3.3v and Grnd to both the logic shifters and radio card. Bob |
