Chris Edwards | 03/07/2022 00:20:27 |
3 forum posts 5 photos |
I recently purchased an old ml7 which came with a large amount of tools and random pieces, including this piece, it's around 100mm high 65mm wide and 115mm between mounting holes.. any help would be great. Thanks Edited By JasonB on 03/07/2022 06:52:33 |
Hopper | 03/07/2022 07:28:27 |
![]() 7881 forum posts 397 photos | Not a recognisable Myford accessory or even general lathe accessory to me. Could possibly be some kind of worm and wheel reduction gearbox? A peek inside one or two of those inspection covers might help. If you spin that disc coupling with the two pins sticking out of it, does the other shaft sticking out the side turn a tiny amount? If it's a worm and wheel reduction box, could be someone was thinking of making a dividing head etc out of it. Edited By Hopper on 03/07/2022 07:29:26 |
not done it yet | 03/07/2022 07:31:28 |
7517 forum posts 20 photos | Demagnetiser? What is inside that little inspection/adjustment cover? Is that a special electrical connector at bottom right on the first pic? I think there could be some better description, than just pics and dims. |
Baz | 03/07/2022 10:45:13 |
1033 forum posts 2 photos | You don’t know what it is, nor do I but I would have removed the thumbscrew and seen what’s behind the cover. |
Chris Edwards | 03/07/2022 10:56:36 |
Edited By Chris Edwards on 03/07/2022 10:58:09 |
Brian Wood | 03/07/2022 11:11:10 |
2742 forum posts 39 photos | Hello Chris, Aircraft War surplus slow motion drive and I think with various speed ratios at the shafts with pegged flanges Brian |
Chris Edwards | 03/07/2022 21:48:01 |
3 forum posts 5 photos | Thanks a lot for the identification Brian, it really has me scratching my head trying to figure out it's relationship to the lathe.. 😆 |
